Close task in Noysi as trigger for automation
Status: Closed · Asked by Elma on · 0 views
Elma — Question ·
I managed to create an automation, where when doc files are saved in google drive in a specifc folder, a task is automatically created in Noysi via pabbly connect.
Now, the person assigned to the task has to review the document, and when he/she approves it, close the task. However, I don't find this trigger in pabbly connect. Pabbly connect can close the task automatically, but this one, I need a person to do it, and when the task is closed or approved, then that's when the sequence of automations start (like uploading to wordpress blog, etc.)
Please check how this can be done. Thank you.
Hey @Elma
Kindly briefly elaborate on your use case once and let us know the name of the application which you are trying to use in your automation. Also, share the name of the workflow in which are trying to implement the same.
Elma — Reply ·
Hi, the software is NOYSI
Trigger must be when task is approved, the following is triggered:
1. Get Details on Google Docs
2. Post to Wordpress
Hey @Elma
Do you want to capture the webhook in the Noysi and then pass the data to Google Docs or WordPress?
