Code (Pabbly) Static IP
starta
Hey, I added to the workflow a Code (pabbly) python step.
My goal is to connect to a ftp and get the newest file. But i need to whitelist the IP on the FTP to be able to connect. Now i wanted to check if the server on that the python script is running is always same.
To check I used this script:
Is this public ip always the same or does it change?
best regards
Hello @starta,
The code currently fetches the IP address of the machine it runs on, so it will return the same IP address each time. However, you can modify the code as needed to meet your specific requirements.
