Comment youtube : Manual sending
Status: Closed · Asked by thomaslancien on · 0 views
Hello, I have connected my youtube channel with open AI in order to automatically reply to comments on my youtube channel. My question is: Is it possible to not publish automatically the answer generated by open AI, but to let me choose to publish MANUALLY each answer?
That is to say:
1. A user writes a comment on my youtube channel
2. Open AI generates a reply
3. The generated answer is ready to be sent from my youtube interface and I can still edit it before clicking to publish it
What I want is not to send automatically and necessarily every answer generated by Open Ai but keep the manual choice to do it or not
Thanks in advance
Hey @thomaslancien
Try using Google Sheets in your workflow at the last step to add the comment where you can decide whether to post that comment or not.
And create another workflow that will fetch the comment from that particular Google Sheets to post on Youtube.
(For similar logic)
