Complete automation not executed
Status: Closed · Asked by yash.yks on · 0 views
yash.yks — Question ·
Hello Team,
Task History ID: IjI4ODc3NjYzIg_3D_3D
Not all steps were executed in the above task. What's the issue?
Please help
Pabbly — Reply ·
Hey @yash.yks
Sorry for the inconvenience. Please allow some time to check on this.
We will get back to you in a while.
yash.yks — Reply ·
same issue with below task also
Task History ID:
IjI4OTM5MDYxIg_3D_3D
Please check
yash.yks — Reply ·
I think something is broken
Again same issue with
Task History ID:
IjI4OTYwMTI3Ig_3D_3D
Please help ASAP
Pabbly — Reply ·
Currently, we don't support having delay steps inside a router. We request you to kindly remove the delay step which you're currently using inside the router of the workflow named "BM Course - Rs 299" so that further steps of the workflow can be executed.
Further in the upcoming days, we will also support having delay steps inside a router.
Thanks for your understanding!
yash.yks — Reply ·
But it was working fine since so many days
Why it suddenly stopped working since 1 day?
Pabbly — Reply ·
We request you to wait till Monday as we will be making a deployment after which the delay step will start working inside the routers as well.
We will notify you as soon as we push an update on Monday.
Pabbly — Reply ·
@yash.yks
You can now use delay step inside routers as well. Kindly login to your Pabbly Connect account and test at your end.
