Connect Flow
Status: Open · Asked by Dan Cook on · 0 views
Dan Cook — Question ·
Hi there,
I have hit a snag.
I am trying to connect a flow back to my main menu, which is named "Welcome".
But It is only showing 10 flows and so the main menu one is now unaccessible.
Is this a bug that is being worked on?
In meantime how do I link back to main menu if it is not accessible?
Hi @dan90,
Could you please make a short screen recording and elaborate a bit more on the exact issue you are encountering?
Dan Cook — Reply ·
From this you can see I have 11 flows (I did have more but I needed to delete some to make connectors work).
When I go into a specific flow and use a flow connector the list only brings up 10 flows and not all flows.
I previously had more flows and so it made it worse as 4 were unaccessible.
The list shows only 10 of my 11 flows and it really does limit the system when you can't access all of them.
Thank you for sharing this information. Please allow us some time to look into this concern. We will get back to you with an update soon.
The issue has been resolved. You should now be able to see all the flows under the 'Connect Flow' node.
Dan Cook — Reply ·
Thank you Arshil!
