Connect GoCardless recurring customers with Mailerlite Group
Status: Open · Asked by tabitha-stapely on · 0 views
My non-profit organisation offers recurring monthly 'donation' plans to support the local journalism we produce. We call this 'membership' and we want all 'members' paying monthly donations on GoCardless to be signed up to our Mailerlite mailing list and for them to be added to a group called Members so that we can send them special content.
So far I have successfully connected GoCardless with Pabby using a webhook endpoint in the GoCardless sandbox.
WORKFLOW 1
One of my donors signs up (*Q1) for any plan on GoCardless.
- Customer is subscribed to my Mailerlite subscriber list and added to Mailerlite Group "Members"
- If they are an existing Mailerlite subscriber, their record should be updated to be added to Group "Member".
- If they were in Group "Former Member" they should be removed from Group "Former Member"
WORKFLOW 2 (***Q3)
Customer cancels (**Q2**) all their GoCardless subscriptions.
- Customer is moved from Mailerlite Group "Member" to Group "Former Member"
QUESTIONS
*Q1. What is the correct trigger for a customer 'signing up'? Is it: payments > payed_out? or payments > confirmed? or subcription > confirmed? or mandates > mandate_created? To consider is that some customers have more than one subscription/mandate. Also, some payments fail because of low funds but then succeed when retried.
**Q2 . (?**) What is the correct trigger for 'cancelling'? subscription > cancelled? What if they have cancelled one subscription but still have another?
***Q3. Do I need to create two separate workflows, one for when a customer signs up and another for when a customer cancels?
Q4. How do I apply this workflow to existing customers? Or will it do that automatically?
Q5. I have 350 existing GoCardless customers but more subscriptions as some customers are on more than on plan. How do I make sure that when a customer cancels one of their subscriptions, but not another, they aren't moved into Mailerlite Group "Former Member". ?
Q6. A Pabbly agent sent me screenshots of what the Flow should look like. In the Pabbly Router it shows a Flow called "recurring payment" and "cancelled payment". I have connected Gardless with a webhook endpoint successfully (in sandbox) but I can't find these two options. What am I doing wrong?
Hi @tabitha-stapely,
So far I have successfully connected GoCardless with Pabby using a webhook endpoint in the GoCardless sandbox.WORKFLOW 1
The use case you are describing seems possible. You will need to add a Router to your workflow. Please establish a connection with your MailerLite account, and we will try to help you with the routes.
Follow the steps given in the video below to establish a connection with your MailerLite account.
youtube.com/watch?v=TR3u7yILDhM:519
WORKFLOW 2 (***Q3)Customer cancels (**Q2**) all their GoCardless subscriptions.
You will need to get in touch with the GoCardless support team to understand if they have a webhook event that triggers on the cancellation of all subscriptions for a particular user. Only then can we assess the possibility of this use case. This doesn't appear to be possible at the moment.
QUESTIONS*Q1. What is the correct trigger for a customer 'signing up'? Is it: payments > payed_out? or payments > confirmed? or subcription > confirmed? or mandates > mandate_created? To consider is that some customers have more than one subscription/mandate. Also, some payments fail because of low funds but then succeed when retried.
You would have to contact GoCardless's support team for a better understanding of this concern, as they are better equipped to handle this query. We don't have much information regarding this.
Yes, you would have to create two separate workflows.
Only new customers signing up will trigger 'Workflow 1'; it won't trigger for existing customers. It's not possible to add existing customers to the MailerLite subscriber list through automation.
You can add a Filter as step 2 of your workflow and set the conditions such that the next steps of your workflow are executed only when the customer cancels a particular subscription.
Could you please elaborate a bit more on this?
