Connect Pabbly Connect with OpusClip
Status: Closed · Asked by Dr. Igor Hodorkovski on · 0 views
Igorjosch — Question ·
Dear Pabbly Team,
I would like to ask whether there is currently, or will soon be, an option to connect Pabbly Connect with OpusClip, in order to create an automated workflow for example, automatically uploading videos, processing them via OpusClip, and retrieving the finished clips along with captions.
Thank you very much in advance for your response.
Kind regards,
Igor
Himesh Soni — Reply ·
Dear Pabbly Team,
Kind regards,
Igor
Hello @Igorjosch ,
Right now Opusclip connection is not available in pabbly connect. But you can submit a request here : https://roadmap.pabbly.com/b/Integration-Request
FYI I'm not from Pabbly Connect team, just a freelancer who helps other Pabbly users.
Automation Freelancer
Email - [email hidden]
Igorjosch — Reply ·
Hello @Igorjosch ,
Hi Himesh,
thank you for your reply.
Do you happen to know any alternative for this? I will create a feature request in the meantime.
Best regards,
Igor
Igorjosch — Reply ·
What's your exact usecase or what do you mean by processing? check out this app https://www.pabbly.com/connect/integrations/json2video/
I want to automatically cut the videos I record myself into shorter Reels (for example, in OpusClip) and then post them on Instagram. I believe JSON2Video doesn’t really do that, but thank you for your recommendation.
There are other tools available, such as Klap and Vidyo.ai, but they are not available in Pabbly Connect.
Igorjosch — Reply ·
