Connect Thrivecart using API by Pabbly
Status: Closed · Asked by Vanessa M on · 0 views
Hi, I'm lookiing to set up a connection with Thrivecart so that when another form on Fluent Form is filled, the data is sent to Thrivecart and the student is registered on Thrivecart Learn.
I have set up the connection with Fluent form but struggling to connect Thrivecart using the API... How can I achieve this? Thanks in advance.
Hey @Vanessa M
It seems like the Thrivecart API doesn't offer any action step to register the user. So your use case might not be possible with the Thrivecart.
