Connect to TidyCal does not work
Status: Closed · Asked by Urmila on · 0 views
Connect Button to TidyCal does not work
I try to create a workflow, I choose TidyCal as Triggers
& the button Connect to TidyCal does not work.
Is there is a bug to Connect Pabbly to TidyCal ?
I have created another workflow with Thrive Cart,
following the instructions given & I have been Successful
Do I have to Create API Keys in TidyCal & How to do that !
I am not a Geeky Tech Stuff person, it is not my field of expertise.
This is the Screenshot in Pabbly, with the Button that does not work
& This is in Tidy to Create custom integrations
& After That this Window ... but I am Stuck at that point on how to move forward.
Thank You for Support
Hey @Urmila
The Tidycal trigger event has an oauth2.0 authentication to which you can connect it directly without passing the API.
Kindly, try connecting the trigger event in the Incognito mode of your browser.
I hope this might help you out.
