Connect Uncanny Automator with Pabbly
Status: Closed · Asked by FrancescoM on · 0 views
I would like to create an automation for canceled subscriptions on WooCommerce.
My idea is to create an automation with trigger starting from Uncanny for each canceled WooCommerce subscription. Then data should be transmitted from Uncanny to Pabbly and from Pabbly should start an automation which brings the tag "Canceled Subscription" to Vbout platform. Is it possible to connect them like this?
Hey @FrancescoM
If the Uncanny platform supports the webhook facility then you can use the Webhook by Pabbly trigger event to capture the webhook response from it.
Further, you can process its data with the WooCommerce action step on Pabbly's workflow.
