connect whatsapp to woocommerce through pabbly
shahnoor
can i connect whatsapp to woocommerce in such a way that people should place order directly from whatsapp ,suppose now if customer sends me some random message on whatsapp and for that the reply has to go to choose support button and order button now once the customer clicks to order button all my products details from my woocommerce has to appear in the message in the form of menu. for better understanding please check the below screenshot that i have sent please let me know if this is possible and how is it possible to do it, thank you so much.
Supreme
Hey @shahnoor
You can try the same in your Pabbly account once, you can refer to the following video tutorial on how you can use the WhatsApp in trigger event to capture the webhook response.
(Watch the first part of the video)
(Watch the second part of the video on how you can create the order)
shahnoor
Hi, i am unable to set when i try to setup Whatsapp cloud API it is showing me error like
Onboarding Failure
An error occurred while processing this request. Please try again later.
I have also attached the image below please help.
Thanks alot
shahnoor
Hi, i am unable to setup whatsapp api when i try to setup Whatsapp cloud API facebook meta for developers page.it is showing me error mentioned below
" Onboarding Failure
An error occurred while processing this request. Please try again later."
Thanks alot
