Connect with Interakt for Bday messages
Status: Closed · Asked by ac24365 on · 0 views
I am trying to connect Pabbly with Interakt for Bday messages thru WA.
I managed to connect my google sheet using the video tutorial. However, Pabbly doesnt fetch the birthday from the sheet used.
Need assistance is solving this asap.
Kindly guide
Hey @ac24365 !
Kindly check on the image below-
It seems you dont have the same data inside your Google Sheet because of which it is not able to fetch any data for it.
You can simply add a dummy data inside your Google Sheet, so it fetches the data for you and you can further complete the setup of the workflow.
Data is there in the files mentioned. Please chk screenshot
Can someone come on Google Meet to handhold pls?
Hey @ac24365 !
We have added the / for you and now you can continue further with the workflow setup-
Kindly follow step to step guidance as per the video tutorial you are following, as every step are shown in it.
Thank you!
That was helpful.
I have a sheet with 3000 data rows.
Step
4. Google Sheets : Lookup Spreadsheet Rows V1
Getting this error "
Response not received in 25 seconds.
Learn more: https://forum.pabbly.com/threads/pabbly-connect-timeout-limit-error-response-not-received-in-25-seconds.855/"
How to resolve this?
I managed to solve the problem using V2 of Lookup Spreadsheet Rows.
