Connect Zoho Marketing Plus in Pabbly Connect
Editor
there are many Zoho apps that I can connect to in Pabbly Connect.
Is there a way to connect to Zoho Marketing Plus? Zoho Marketing Plus is already months available and more and more people use it, so it would be great to use inside Pabbly.
Regards,
Jos
ArshilAhmad
Moderator
Hi @Editor,
If you wish to see Zoho Marketing Plus added to the Pabbly Connect platform, you can place your request here: https://pabbly.hellonext.co/
After you submit your request, our integration team will review it and, if possible, add the desired application to the platform.
