" Connecting Brevo with Partnero "
Status: Closed · Asked by Ahmed Lotfy on · 0 views
Please is there anyway to connect Brevo to Partnero? when someone submit to brevo form i want the data to be transfered to partnero.
Hi @Ahmed Lotfy,
Currently, we don't have a dedicated trigger application for Brevo, and we haven't integrated with Partnero. If you would like these applications to be added to Pabbly Connect, please submit your request on our dedicated platform: https://pabbly.featureos.app/b/Integration-Request.
Our integrations team will review your request and, if possible, add the desired application to Pabbly Connect.
In the meantime, if Brevo supports Webhooks and Partnero has a REST API, you can try using the Webhook by Pabbly and API by Pabbly modules, respectively, to achieve your use case.
