Connecting FB lead ads with Wix- check it has worked
Status: Open · Asked by Laura on · 0 views
I have followed all the steps to set up a connection between FB lead ad and Wix, but I can't seem to find how to test if what I have done has worked. Do I need to publish the ad to test it?
Laura
Hi @Laura,
Yes, you need to make the lead ads form live, then submit a real lead and see if that triggers your workflow.
Hi @Laura,Yes, you need to make the lead ads form live, then submit a real lead and see if that triggers your workflow.
Hi thanks for the reply yes the form is live but I don't seem to see how I check it is all working - I wondered do I need to publish the ad?
You can publish the ad to capture real leads or use the Lead Ads Testing Tool to test your workflow.
