Connecting FB Leads to Systeme.io
Status: Open · Asked by Johnlyn on · 0 views
Hi there!
I'm trying to connect FB Leads to Systeme.io. It creates a contact when someone submits their name in my FB lead form but when I try to add the tag after that it works in the test mode but then doesn't add tags for my new contacts.
The message is: The application processed the request but returned a blank response. Refer to the HTTP status code above for details. (but it still adds the tag to my test email account)
What can I try?
Hey @Johnlyn
I kindly ask you to reconnect with the application and then try the task again.
Thanks! I did that for just "add tag to contact" step and it added it one time but then didn't add it for the next contact.
I have made a slight change to your workflow and mapped the Contact ID from the 2nd step. This change will now tag your newly created contacts.
Thank you! I had to stop my FB ads so will more than likely need to do this again...so I need to map the contact ID when I set it up again?
Yes, you would have to map the contact ID.
