Connecting Mindbody and GHL
Status: Open · Asked by EasyBizTech on · 0 views
EasyBizTech — Question ·
I am trying to connect my clients Mindbody (booker.com) account with GHL. I have talked with Mindbody support and they asked me this....
The Booker API has a step to generate an access_token before you can begin making API calls to get data. Do you know if this tool you are using allows you to chain calls together and read the responses? You may need to have some understanding of how the Booker API functions, have you seen the documentation?
Pabbly makes it look easy with just two fields to enter
But mindbody gave me 4 pieces of information
Pabbly is wanting my API key and Site ID
I was given this from Mindbody (Booker)
The Booker Staging API credentials for your account are:
client_id: xxxxx
client_secret: xxxxx
Customer API Key: xxxxxx
Merchant API Key: xxxx
This account will have access to the Booker API test site, "xxxxxxxxxxxxxxxxxxxx", LocationID: xxxx
Which one of these goes into the Pabbly API key and which one is the Site ID?
Ted
