Connecting Perfex CRM to Mautic
Status: Closed · Asked by siyengar on · 0 views
Is it possible to send a Perfex lead into Mautic as a contact? What do I need to make this happen?
It seems Pabbly shows a way to go from Mautic to Perfex but not the other way around.
By the way, I already have a separate workflow to send leads from Dripify to Perfex through a Pabbly web hook.
I don't know if that affects having a second workflow to send leads from Perfex to Mautic.
And, for clarity, I'd like to know how often Pabbly updates leads or runs the workflow.
Please let me know.
Thanks.
Hey @siyengar
As of now, Perfex CRM's trigger event is not available on the platform but you can post the request to add the integration here - https://pabbly.hellonext.co/
Our integration team will look into it and add it accordingly.
It's been about a week since I posted the request to add the Perfex CRM trigger but there has been no acknowledgement or reply from your integration team. Please let me know because I'm thankful I found your product and now look for a better solution. Thanks.
Pefex CRM has launched webhook so you can easily integrate them in Pabbly Connect in trigger step - https://codecanyon.net/item/webhooks-module-for-perfex-crm/38350010
