Connecting TypeForm to HighLevel and passing custom fields
Status: Closed · Asked by socialseobuilder on · 0 views
I have TypeForm connected to HighLevel. The webhook is working and I get a response and can map the data; which is first name, last name, email and phone. But I ask some additional questions on my TypeForm and I added the fields in HighLevel as custom_fields but Pabbly doesn't give me the option to pass those custom fields to HighLevel. I can see the answers to the questions being received from the TypeForm webhook. But I don't see an option to map those answers to my custom fields in HighLevel. How can I fix this issue?
Hey @socialseobuilder
As we can see from your workflow, after reconnecting your Lead Connector action step we can see your custom fields correctly.
Please do reconnect the action step and map the data accordingly.
@Supreme I see that the custom fields are only available when you 'Update Contact'. What I need is the custom fields to be able to map on the 'Create or Update Contact' option. Is there a way to get the custom fields added to HighLevel when creating a new contact or you can only use custom fields after the contact has already been created in HighLevel? If I have to do a 2nd step to add the custom fields after the contact is already created, how do I do that automatically? In my Typeform, I ask for First Name, Last Name, E-mail, Phone #, but I also ask for additional custom fields. But when creating a new contact in HighLevel, Pabbly does not give me the option to pass the custom fields that was collected with the Typeform submission. So that is the problem I am trying to solve. Can you help me figure out a solution to add the custom field values at the same time of adding a new contact to HighLevel?
I think I figured it out. I had to refresh everything on Pabbly and now the custom fields are showing up. Thank you.
