Connecting with Deskera
Status: Closed · Asked by vgp on · 0 views
vgp — Question ·
I'm trying to connect deskera triggers with pabbly connect. I want to create a workflow where if a new deal in added in deskera crm, it should be automatically be added in a google sheets file. When i am creating the trigger, it is asking me to create a connection. I've created it and it shows 'connected'. But when it asks me to do a test where i'm supposed to add a new deal in my crm and pabbly should listen for it and capture it, it is stuck and and is not able to capture anything and simply keeps listening without any end.
Hi @vgp,
Please create a new workflow and select 'Deskera: New CRM Deal' as your trigger application. Then, follow the steps shown in the video shared below to set up a new connection with your Deskera account (Only the connection process is relevant for you). After that, click on 'Save & Send Test Request', create a new CRM deal, and check if it gets captured in the trigger step.
youtube.com/watch?v=cWLTpnS0fwM:226
