Connecting WordPress Blog using XML-RPC
Status: Closed · Asked by Anson on · 0 views
Hi Support,
Is it possible to allow Connecting WordPress Blog using XML-RPC?
As in the free plan of Wordpress.com, we cannot install a plugin to connect the blog.
Please consider adding this feature, as currently in ContentStudio app. Thank you.
https://docs.contentstudio.io/article/475-connecting-wordpress-blog-using-xml-rpc
Hey @Anson
Please send the request here and upvote the same - https://pabbly.hellonext.co/b/Update-Existing-Application
The integration team will look into it.
Thanks!
Did this get implemented? I need it, too.
Hey @webforhire
You can post the request or upvote the existing request on the platform here - https://pabbly.hellonext.co/
