Connection to CopeCart
Status: Closed · Asked by Daniel-FXS on · 0 views
Daniel-FXS — Question ·
I am trying to set up a Connection to CopeCart via Pabbly and it gets stuck in the "waiting for webhook response". I followed all the steps described here to set up the IPN trigger (created new generic integration in CopeCart, copied webhook URL from Pabbly into the CopeCart notification URL field) and did several test payments in CopeCart.
Is there anything missing or to consider?
Thanks!
Daniel
Hey @Daniel-FXS
Can you please record a short video on how you can configure the trigger event and capture the webhook response, along with that please share the workflow URL once.
Daniel-FXS — Reply ·
Thank you for your quick reply. I just reproduced the workflow again and recorded a video of it. Can I share the video with you in a private message (or re-start this thread in the private forum)?
SOLVED - double-checked with webhook.site (CopeCart is sending successfully the webhook), then set it up again in Pabbly and did a test purchase and the webhook was received. Thank you.
