Connection to KIT not working
Status: Open · Asked by Asa on · 0 views
Hi! I am trying to set up a connection from Facebook to a sequence in Kit. I have put in both API and the secret API for Kit as requested. I have double checked, they are correct. When I send a test request message Authorization Failed API Key not present. I have tried with deleting everything with Kit and started over again, same result. I need help with what to do.
UPDATE: I used the classical way to set it up and this time it worked. So it is solved.
Hello @Asa,
Could you please provide us with the Workflow URL where you are facing this issue, along with a screen recording showing the connection process with Kit This will help us investigate the problem more effectively and assist you accordingly.
[IMG width="637px" height="191.917px"]https://lh7-rt.googleusercontent.com/docsz/AD_4nXdhUKey9--1ZdBRxy3UK5P5fDJKizdxrQDoL8zlve4yt3YDpDREwIp1qPAxtgqRMWDxjtdOIt8phHaEwxppC5qiyDyp1S_EATVhFG8E8floJo6Esv6ih3tBAUUcZQjdUDvBlAu_ew key=nsDumdqHFySLv4i3KkkEsp9o[/IMG]
