Connection to particle.io
Status: Closed · Asked by sldeese9047 on · 0 views
I have devices that are part of Particle. I have access tokens, device numbers and names and the events. I cannot get the function Get to operate. Any ideas of steps to follow? I can get it to operate on other apps.
Hey @sldeese9047
Please provide the name of the application you are trying to set up and use with Pabbly Connect. This information will help me assist you more effectively.
I am wanting to go from Particle to a WordPress site using elementor. I want to show this information on the website as a dashboard for an IOT device. I seen the New curl command add to your trigger API , and I am working on using this now.
I have reviewed your workflow, and it appears that you are correctly using the "Webhook by Pabbly" to receive responses from Particle.
To integrate this with WordPress, you need to add the WordPress action step to your workflow. Map the details from the webhook response to the WordPress application to ensure proper functionality.
If you face any issues or need further assistance, feel free to let me know.
