Connectioning Go High Level to Kixie power Dialer
Status: Open · Asked by gerardmuhammad on · 0 views
How do I set up an API webhook in pabbly
Hi @gerardmuhammad,
Could you please elaborate further on your exact use case? This will help us gain a better understanding of your concern.
I need to learn how to configure the webhook to work. Kixie is a power dialer that dials ten numbers at a time. It also sends SMS text messaging, and I'm creating automation that happens when we upload a list and when we receive new leads into the CRM.
Hi @gerardmuhammad,
You can follow the steps provided in the first half of the video shared below to set up LeadConnector as your trigger application and capture the leads.
youtube.com/watch?v=6wTaOh1AZZQ
Currently, we don't have a direct integration with the Kixie application. If it has a REST API, then you can try using the API by Pabbly to execute an endpoint.
