Create a google sheet where to save data from a work flow
Status: Closed · Asked by Tobia D'Odorico on · 0 views
dodosport — Question ·
Good Morning to everyone.
I need help to know if it's possibile to create a google sheet in which I've to insert datas as a result of a workflow.
I explain my situation better.
I've a fashion store in Italy and I have a loyalty program in cloud. Unfortunately yesterday eventing My database was erased but I don't know if it's my fault or is a bug from the platform.
In any case I need to restore datas of each owner of a fidelity card.
In pabbly connect I've created some workflows that integrates with the platform of my loyalty program.
Going more specific I created a workflow that every last day of the month sends a Whatsapp Message to each card holder with how many points they have.
To obtain these datas I made in the workflow an API call to the loyalty program platform that sends as answer every single data of each holder and card.
Then with iterator I create every single message.
So is possible to create a google sheet in which I can insert these datas from the API CALL? (NAME, SURNAME, PHONE, NUMEBR of CARD, POINTS ....)
Thanks if some one could help me.
Tobia
Hey @dodosport
Can you please explain this part of your case so that we can suggest your query accordingly? Also do share the workflow URL in which you have tried the same.
