Create a Task in ClickUp when an Issue in JIRA Software enters a specific Status and add the ClickUp task ID to the JIRA Issue summary
Status: Closed · Asked by sune@optix2023 on · 0 views
I used the trigger of when a new task is created in JIRA and goes into a status called IN UAT. Once this happens the task should be duplicated in ClickUp. My flow works fine until here. When I try to add the ClickUp task ID to the JIRA Issue Summary to be able to allow for 2-way integration using an additional flow I get an HTTP Code of 204 and nothing happens and no update was made on the JIRA Issue. This is really frustration please help!
Hey @sune@optix2023
Kindly share the email address or workflow URL in which you have faced such an error so that we can check on it.
