Create and Update WooCommerce Products
Hello!
I attached below my spreadsheet layout, so please, how can I setup a workflow where:
1) for each new row, the automation creates a new WooCommerce product
2) for each update in an existing cell of above row, the automation updates the corresponding product
Hey @oibrunosilva
The workflow seems fine to us, though it seems like you haven't connected your WooCommerce account correctly.
Kindly try to re-connect your WooCommerce account properly and then map the fields accordingly.
Moreover, you can refer to our tutorial video for you better understanding of how you can connect the action step.
