Create contact not working in High Level
Status: Closed · Asked by Wesley Edgar on · 0 views
My workflow captures information via webhook, then I want to use that information to create a contact in HighLevel.
If I manually enter the contact information to be sent to High Level it works, however when I use the information captured via the webhook, it fails and gives me this response:
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<title>Error</title>
</head>
<body>
<pre>Bad Request</pre>
</body>
</html>
I've wrapped my head around this and at this point I feel like it would be more straight forward to write a custom API POST.
Any one else experienced any issues with this?
Any insight is appreciated
Hey @wedgar
As we can understand, it seems like you are passing the tags without double quotes and because of that, the error is coming.
Kindly try passing the tags in double-quotes.
