Create Draft Order in Shopify Not Showing Price
Status: Closed · Asked by Carlos Lupiac on · 0 views
Have automation creating draft order based upon trigger tag. Works but no value appears on the Draft Order
Currency is USD
Line Item Product Price is listed as 1299.99
I have also tried 1299 and $1299. Value always appears as $0 on Draft Order. See attached.
Hey @mktg2contractors
Can you please share the workflow URL once in which you have tried the same?
Hey @mktg2contractorsCan you please share the workflow URL once in which you have tried the same?
https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTY5MDYzMTA0M2Q1MjZkNTUzZDUxMzIi_pc
Kindly pass the product ID Line Item Product field and then try again, since the API only accepts the ID of it.
