Create Task in Nifty not dynamically entering Project ID
Status: Open · Asked by RoCrow on · 0 views
RoCrow — Question ·
Task History ID: IjU3NmMwNTZiMDYzNDA0M2M1MjY1NTUzMzUxM2E1MTZhNTQzMyI_3D_pc
I have this workflow that has step 13 that pulls in a Nifty project ID from a Google Sheet:
In step 14 I have a Nifty PM: Create Task action.
For the Project ID field I have it set to Map (on) and am using the Step 13 project ID value:
Note that it's the same ID.
However, the task is always created in the same project, regardless of what the project ID is in step 13.
If you see the supplied task history ID, you'll see an ID value in penultimate step that is different to the project ID mapped from it in the final step
Can you take a look and see what's wrong please?
Hi @RoCrow,
Could you please make a short screen recording executing your workflow twice, each time fetching a different project ID from Google Sheets and using it to create tasks in Nifty PM? Additionally, in the same video, show where (in which project) these tasks are being added in your Nifty PM account.
We have moved this thread to Private Discussions to maintain confidentiality.
