Crove Integration - missing input fields and response data
Status: Closed · Asked by Jeff Huen on · 0 views
Hello - a couple issues I noticed for the Crove integration:
1. the action to Generate Document PDF From Template appears to be missing the file name input.
Is it possible add this back in so that we can dynamically name the file using information from the captured response?
Otherwise, it would require an extra step to call the Update Document action.
2. Response: The response should also have the generated PDF URL, but for some reason it's missing. Can we get this included so that we don't have to call the action "Get Document Details"?
We advise you to speak with their staff since it looks they were the ones who established the integration of Crove on the platform.
The API response always sends by the application from their server, Pabbly does not interfere with the incoming API response.
So, you would be required to contact the Crove support team once to send the URL in the response.
