Crove.app OneDrive pdf upload issue
Status: Open · Asked by Felipe Arbeláez on · 0 views
felipearbelaez — Question ·
I tried uploading a pdf document to OneDrive and it keeps generating an error, and even though the file is "uploaded" it never opens. You always get the error below. However, if I try to do the exact same process for Google Drive, the document uploads without any issues. We do require to be able to upload to OneDrive, as we use Microsoft suite for this company.
Hey @felipearbelaez,
Please share your workflow with us at the provided email address so that we can gain a better understanding of your issue. Once you have shared it, do let us know the name of your workflow.
felipearbelaez — Reply ·
I just sent you an email. Thanks!
Have you tried uploading the generated PDF file directly to OneDrive? Does it produce the same error as when you upload it through Pabbly Connect?
Do you mean manually uploading the PDF doc to OneDrive? If so, yes, it works without any issues.I just uploaded a document that was just triggered by the workflow, and it worked just fine.
Could you please confirm if your issue is resolved?
No, the issue persists
Hey @felipearbelaez
Can you please share the task history Id in which you get the failed task so that we can look into it?
There seems to be a bigger problem with OneDrive. The original error I encountered I can only replicate when reattempting to set up the workflow; once the workflow is executed by a new task automatically, it fails to execute with an "InvalidAuthenticationToken" error. If I try to authenticate the same account, it works again, and I replicate the pdf issue I explained when I created this thread, but it seems like it the OneDrive connection times out somehow, and it doesn't work once it's set up.
You can check task ID IjU3NjAwNTZiMDYzNDA0MzY1MjZlNTUzMjUxM2I1MTYxNTQzNyI_3D_pc as an example.
Could you please provide me with access to the workflow that corresponds with this task ID?
As we can see from the error message from the respective task history Id, we can see that you might have done some changes in the OneDrive account and because of that the connection got void. So, please make a new connection and then try again.
I just reconnected it, and Save and Send Test Request, and got the same result, the PDF won't open. The file appears to be empty
