Custom api not saving and not working
Status: Closed · Asked by Colin D'Cruz on · 0 views
Hi, My Custom API call is not working.
In fact, it is not even saving.
Pressing Save and Sent Test Request does nothing.
I have tested it out in Postman and it works fine.
Please help.
Thanks,
Colin
Hey @colind
Could you please share the CURL request from your Postman's API request along with the API documentation? So that we can look into it.
I have the same issue which I noticed today
When I create simple API (for example GET), I can save it properly.
But I need to use custom POST API, but I cannot save and I cannot test data either.
In older workflows, my custom APIs are properly saved and working.
Hey @colindCould you please share the CURL request from your Postman's API request along with the API documentation? So that we can look into it.
Hi, I think you can test with anything API custom POST, you can't save in Pabbly at all...
It works for me now...
