Custom field created in PipeDrive Deal not showing in Pabbly Connect
Status: Closed · Asked by Madhav on · 0 views
Madhav — Question ·
Hi, I have created a custom field in Pipedrive in deals. It is not showing by default in "Create Deal" in pipedrive integration. How to do it?
Hey @Madhav
To pass the custom fields in Pipedrive's "Create Deal", you need to add fields with the help of the + button. Then you need to pass the key value of the Custom field which you will get from the "Get All Deal Field".
Further, for better understanding, you can check the following short recorded video.
https://www.screenpresso.com/=pr94b
Madhav — Reply ·
Thanks a lot. This works
