Custom fields not showing with pabbly integration
Status: Closed · Asked by factoryskylight on · 0 views
Task History ID: IjU3NjMwNTZmMDYzZTA0Mzc1MjZmNTUzZDUxM2E1MTZhNTQzMiI_3D_pc
After creating my custom fields on Pipedrive then I wanted to connect it with my elementor {they both have the same fields} using Pabbly but I was unable to see the custom fields I created and I've tried every possible thing. Pls is there any way to go about it, I'll need help.
Hey @factoryskylight
Could you kindly provide me with the custom field name that is identical in both the Pipedrive and the Elementor form? This will enable me to investigate the issue further and assist you accordingly.
