data coming through as a long string
Status: Open · Asked by andrear on · 0 views
Response comes through from emailOctopus as a long string (with all fields) when creating a new client. See below. Was in fields before. So cannot select individual data to send. Please let me know how to deal with this. Thanks
[{"id":"b2c67abe-c565-41cf-8f69-a7963c8e89a5","type":"contact.created","list_id":"8b602f7a-fc31-11ef-91d1-3f9b575f27d1","contact_id":"acba5342-10dc-11f1-a1e8-1b4d501b40b6","occurred_at":"2026-02-23T17:25:40+00:00","contact_fields":{"Date":"2026-02-23","Address":null,"LastName":"rosen","FirstName":"andrea"},"contact_status":"SUBSCRIBED","contact_email_address":"[email hidden]"}]
Hi @andrear,
Upon reviewing your setup, it appears that the response has been captured in Advanced Format, which is why the output is appearing in a single line (raw JSON format).
To receive the response in a structured key-value format, please follow the steps below:
- Open your workflow.
- Go to the Trigger step.
- Change the response format from Advanced to Simple.
- Click on Re-capture Webhook Response.
- Perform the trigger event again from your trigger application.
Once done, the response should be captured in a proper key-value structure.
Please try this and let us know how it goes.
Thank you. I had changed it to advanced because simple was doing this as well. I created a new workflow and selected "Simple", not Advanced and the same thing happened. This is the link to the new workflow. Thank you for your time.
https://connect.pabbly.com/workflow/mapping/IjU3NjcwNTZmMDYzNjA0MzA1MjZhNTUzNTUxMzci_pc
You need to select Simple Response, then click on the Re-Capture Webhook Response button and create a new contact in EmailOctopus to fetch the response in separate fields. Please follow these exact steps, and it should help you capture the response in the desired format.
Arshil Ahmad
?Rate your support
Thank you but I mentioned that I just created a new workflow and used simple. It doesn’t work.
Please hard refresh your browser, then select Simple Response, click the Re-Capture Webhook Response button, and capture a new contact.
Arshil Ahmad
?Rate your support
Thanks again. Cleared the cache and once again created a new workflow and made sure to select simple response. It definitely stayed on the simple response format, but came through as a single string. See attached
The response is still captured in Advanced Format.
https://connect.pabbly.com/workflow/mapping/IjU3NjcwNTZmMDYzNjA0MzI1MjY4NTUzNzUxMzIi_pc
Anyway, we have added a JSON Extractor as step 2 of your workflow. You can map the data from this step wherever you want.
Arshil Ahmad
?Rate your support
thank you very much. I wonder why it started doing that? Any thoughts.
Also, once again, in the last step defaulted to advanced. Not sure why but when I selected simple seems ok, but then when I hit refresh it switches to advanced.
Could you please make a short screen recording showing this issue?
Arshil Ahmad
?Rate your support
