Data not transfer from pabbly to SQL
Status: Closed · Asked by analytics on · 0 views
Hi there,
I created new workflow, (Url is mentioned below) it is passed data to SQL when in testing phase but after that it is not sending data to SQL, can you please identify the error.
Below is mentioned created date of records which in initiated in razorpay after the workflow setup
[TABLE]
[TR]
[TD]15/03/2024 18:34:34[/TD]
[/TR]
[TR]
[TD]15/03/2024 18:34:46[/TD]
[/TR]
[TR]
[TD]15/03/2024 18:35:00[/TD]
[/TR]
[TR]
[TD]15/03/2024 18:35:13[/TD]
[/TR]
[TR]
[TD]15/03/2024 18:35:24[/TD]
[/TR]
[/TABLE]
/IjU3NjUwNTZiMDYzNDA0MzU1MjY0NTUzMDUxM2Ei_pc
Hi @analytics,
Please follow the steps provided in the video shared below and attempt to set up your trigger step again. Once the payment is captured in your workflow setup, try making another payment as a real customer would and see if that triggers the automation.
