Dataforwarder - webhook help
Status: Open · Asked by robbykasch on · 0 views
robbykasch — Reply ·
also i would like to know does pabbly capture webhook data instantly as its sent? Not that that i have to recapture it with the click everytime? As for the issue above I tried sending data through api, but for some reason i get empty content error all the time (Content, title, and excerpt are empty)
Yes, Pabbly Connect captures data from Webhooks instantly. You don't have to recapture it with a click every time (unless you want to capture new data during workflow setup); once the workflow is set up, the data from the source will be automatically captured, and your workflow will be executed.
Please share the API documentation of the endpoint you are trying to run through API by Pabbly module.
Endpoint is an webhook capture (Uncanny Automator plugin) so theres no api documentation per se
Please allow me some time to discuss this with the technical team. I will get back to you with an update soon.
Hey @robbykasch
Currently, there is no option to pass headers in the data forwarder. You can forward data to another workflow and pass it through the API by the Pabbly action step instead.
youtube.com/watch?v=bmf4och_kTk
Thats what im doing in this workflow, as i mentioned in my second post in this thread, the issue was its giving me empty_content error
I had a discussion with the technical team, and they informed me that without the API documentation, we won't be able to deduce the exact reason for the error you are encountering.
