Date/Time Formatter Issue
Status: Closed · Asked by sbedell on · 0 views
sbedell — Question ·
I am using the Date/Time Formatter to generate just a Ym code:
It appears to work correctly, but when it autogenerates for the next trigger, it is creating a Ymd instead of just the year and month causing an API failure where my versioning must be YYYYMM only.
Thoughts on how to fix this?
Hey @sbedell
As we can see from your workflow and its task history Id you haven't mapped the date from the DateTime Formatter dynamically.
So, seems like the issue is from the API which you have configured in your workflow. So kindly contact the Application's support team for the same.
sbedell — Reply ·
I swapped it to a static LinkedIn-Version from last month this morning. It may be an API issue for 202209 not being active.
Hey @sbedell
Seems like the workflow is processing correctly, let us know if you face any further issue.
