Delay between trigger and gmail
Status: Closed · Asked by JEAN Kevin on · 0 views
Kevin J — Question ·
I hope you're all good, on my workflow I have a tally trigger then I need to send a mail with condition, but there is a delay between I need to send it instantly is it possible ?
I have seen that when people make the tally, the mail is sent approximately two hours after
Thank you for your answer :)
Hey @Kevin J
Tally's trigger events are descriptive-based webhooks that only receive data from the application. Pabbly doesn't alter any data received from the application.
Hence, it's possible that Tally might be experiencing a delay in sending the webhook response.
