Delay Function & Loop
Status: Closed · Asked by Manipavitra on · 0 views
Manipavitra — Question ·
Folks.
I want to create a workflow in pabbly. The workflow will be as below.
My source data will be from an excel sheet > Trigger a msg from WATI > 4 Different msg in a day with different timings > for the next 21 days
I have tried creating the workflow for a day but doing it for the next 21 days is a challenge is there any loop that can be applied so it can trigger for the 21 days?
Your responses will be much appreciated.
Thank you
Hey @Manipavitra
We looked into your use case and it appears that it is not possible to automate your use case.
