Delay in Iterator - (Waiting for Video to Produce) is NOT WORKING
Your Task History ID
IjU3NjAwNTY5MDYzMDA0MzM1MjZmNTUzMTUxMzc1MTYwNTQzNyI_3D_pc
Delay in iterator is not working... I need it to wait for video to produce. But it stops working and continues iterating. See tasks history
A
Arshita
Hey @realestatebroker
As I can check from your workflow, it appears that the presence of both "Delay" and "Iterator" is causing the issue.
I would like to inform you that including both "Delay" and "Iterator" in a single workflow can cause conflicts and result in improper functioning.
Therefore, I recommend that you remove either "Delay" or "Iterator" from your workflow to resolve the issue.
