Discourse Connection : Create Post Error
Status: Closed · Asked by HonestOpinions on · 0 views
I am trying to create a connection to post my Instagram images to Discourse ()
The API connection is setup correctly.
When I save and send a test request, here is the error I get:
From looking at the errors, I think we need to add Title and Category fields to make this work.
Relevant API Documentation for Discourse can be found here: https://docs.discourse.org/#tag/Posts/operation/createTopicPostPM
Hi @HonestOpinions,
Please re-authenticate your account by adding a new connection, and make sure that you are entering the Host URL in the given format.
Same error:
Hey @HonestOpinions
kindly reconnect the action step once and then pass the content in the Title field, please give it a try and let us know if that works for you.
That worked. I will try it out a few more times and let you know if there are any issues. Previously there was no "Title" field as I suggested. Thanks for adding that.
