Divi Engine Form Builder + Spreadsheet
Status: Open · Asked by Karen Bieman on · 0 views
Consent to Access & Modify: I don't authorize Pabbly Support to log in to my account.
Hi, I ue Divi Engine Form Builder for embedded forms, surveys etc on website. The data is saved to the website dashboard, but I want it to save to a spreadsheet (either Google Sheets or even better, Apple Numbers). I can't see Divi Engine Form Builder on Pabbly Connect. Does this mean I can't do it, or is there a workaround?
Hello @karenb,
If Divi Engine Form Builder supports webhooks, then you can use Webhook(Pabbly) to capture the form responses.
Refer to this tutorial for a better understanding -
