Do you know how to keep external url valid for longer than 2 hours?
Status: Closed · Asked by Bananajuice2002 on · 0 views
Bananajuice2002 — Question ·
Task History ID: IjU3NjIwNTY1MDYzZTA0M2M1MjY4NTUzNzUxMzY1MTY2NTQzNSI_3D_pc
I'm experiencing an issue with image URLs that become invalid after two hours following transformation into the desired format. I'm attempting to insert the URL into a Google Sheet from Airtable, but the link obtained is valid for only two hours. I'm seeking suggestions on how to make this link valid for a longer duration using the least number of Pabbly tasks or create a separate workflow that will update the same cell in the Google Sheet every two hours with a new URL retrieved from Airtable.
Thank you for your time and assistance in resolving this issue.
Hey @Bananajuice2002
Opt for Dropbox or Google Drive to upload your file. This ensures continuous access, unlike Airtable's attachment URL, which is only available for limited hours.
Bananajuice2002 — Reply ·
Thanks, that is helpful.
