Does Pabbly Connect have a Sertifier<->Pabbly<->Zenler integration?
Status: Closed · Asked by bibhash on · 0 views
Does Pabbly Connect have the above integration?
If not can you please provide it?
You want Sertifier as a trigger or zenler as a trigger
Here are the links for the both with all available triggers and action -
Sertifier - https://www.pabbly.com/connect/integrations/sertifier/
Zenler - https://www.pabbly.com/connect/integrations/zenler/
Thanks a lot.
I was looking for Sertifier as a Trigger...anyway the other way might also be required.
Hey @bibhash
As of now, Sertifier does not have any triggers. If you want to request adding triggers, please send us the request here and upvote it - https://pabbly.hellonext.co/b/Update-Existing-Application
ok, thanks
