Double optin ActiveCampaign
Status: Closed · Asked by Sophieja23 on · 0 views
Hi, how can I add a double optin for ActiveCampaign? What I would need is to connect the contact to a form within activecampaign because this forms tells to send a confirmation email. But I don't see any settings for this in pabbly.
Or do you have other settings for that. Important is that the contact receives this email for confirmation.
Thanks. Sophie
Hey @Sophieja23
We looked into the Active Campaign's API documentation but we couldn't find the double opt-in option in it to implement at our end.
Although, if you find any documentation related to this, do let us know we will try to implement it at our end if possible.
Hi, thanks. What about addressing a form instead of a list? That would solve the problem...
Hey @Sophieja23
Could you please share a reference of your concern, so that we can look into it and can assist you accordingly?
Hi, at the moment I am trying a workaround with activecampaign to get the double optin via automation. It is really an urgent need in Germany (and the European market I think) to have the function of doi for our subscribers.
What do you mean with reference? What would be great if it workes would be the option not to choose a list but a form. A form in activecampaign will manage in which list the contact will go and also the double optin is set there. Actually the only thing that should be adressed to activecampaign is the name and email address - but of course I don't have a clue about the technique behind
Hey @Sophieja23
As we have checked the API documentation of Active Campaign which we refer to implement an application our platform and double opt-in, selecting forms from a list is not mentioned over there.
So if you can contact the Active Campaign team regarding the double opt-in and the form listing in the trigger event for the documentation on it would be great to implement. Though we have already contacted them for the same.
Hi, I wrote to ActiveCampaign too and hope they will implement this.
Thanks for your help.
Sophie
