Double Sided Referral with PC & Gsheets
Status: Closed · Asked by David Ho on · 0 views
I believe most are familiar with AppSumo Give $10 and Get $10. Is it possible to create this double sided referral with Pabbly Connect and Google sheets?
Any tips and suggestions to get started?
Hey @david
Regarding your concern, I think you might need to contact the AppSumo support team.
@Supreme Can I use PC to build referral system with Gsheets?
Hey @david
You can refer to our tutorial video for a similar usecase.
youtube.com/watch?v=xnCu1sJWhLQ
Kindly try this at your end and let us know if you get stuck at any step or need any further assistance.
