Double Triggering?
Status: Open · Asked by Bananajuice2002 on · 0 views
Bananajuice2002 — Question ·
Hey,
I noticed a bug with my social media workflows — it’s creating duplicate data and generating two identical posts. Is there any solution other than starting from scratch? There are a lot of fields already mapped.
Here’s the workflow: https://connect.pabbly.com/task/history?filter_status=applied&filter_by_workflow_id=IjU3NjYwNTY1MDYzMzA0MzQ1MjZjNTUzNjUxM2Ei_pc
Hi @Bananajuice2002,
https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTY1MDYzMzA0MzQ1MjZjNTUzNjUxM2Ei_pc
'Webhook by Pabbly' trigger is based on descriptive webhooks, which means Pabbly Connect has no control over the data sent by the source application. We simply provide the webhook URL and display the data that the source application sends to it.
If the data is sent multiple times from the source application, your workflow will also be triggered that many times. We suggest contacting the support team of the source application to understand why the same data is being sent multiple times.
Also, we noticed that even though the payloads arrive at the same time, there seems to be some difference in the data received.
https://www.diffchecker.com/cUzoQz4N/
